Quit building or build more?!!!
Nobody likes a quitter....so I did some work, so I can do some more work!!!
First up....the old.
Those shelves were 1x12" - 6', mounted on shelf brackets.
I replaced those with 4, 1x12" - 8', that are all connected as one unit.
I took those three shelves out to the garage and made another shelf unit...connecting the sides with 1x6" and 45ing the corners to match the other.
The old...(1x8")
The new...
I moved one of the old ones over to the main display cabinet (low and center)
Shelf #3 is built and will replace the cheap bookshelf that's in the far right of the first pic. Built and stained it last night...needs a couple days before I bring it in the house.
If I mathed that one right...the shelf height will match with the first shelf unit. If it doesn't, my OCD will kick my arse!
