Citadel Technical Liquid Green Stuff
- Thomas_M
- Admin
Got a pot of this stuff but have no real idea what this is? Is it, as the name suggest, liquid "Green Stuff"?
- scorpiomikey
- Addicted Member
Re: Citadel Technical Liquid Green Stuff
It is literally liquid greenstuff. Its a liquid sculpting putty to smooth out the miniscule seams found in wargaming figurines.
http://fromthewarp.blogspot.co.nz/2012/ ... stuff.html
- Thomas_M
- Admin
Exactly. This is it, Scorpio.
Thanks for the link, interesting discussion on this. Don´t know what I paid for it, so well, in case it will come handy I will give it a try.
- scorpiomikey
- Addicted Member
Ive never used it, but i gather its similar to other products like mr surfacer.
Tigrazor probably knows more since this is his area.
I use it for small gaps and sinking marks. It needs its time to cure but then it sanding characteristics are quite good. It's acrylic based and has no smell plus can be easily thinned and applied with a brush.
The colour is strange
but it helps to find the areas that has to be smoothed out.
- Thomas_M
- Admin
Ah! Thanks! Will give it a try!
Im using it quite often for my figures etc. When it gets too sticky, just thin it a bit with water as needed.
