Glues I use
Glues I use
Bruce (Speedgraflex) asked me an interesting question in my Fw190 topic: What glues do I use.
I started to answer there, but then I realised that this is too big topic to be handled within the AWiP board, so I moved the question here
We all have our own preferencies what we like or not like in glues.
Objective, subjective, "because of", "have always used", "ain't better that this" etc etc.
Here is my current preferred glues... or cement as we also tend to call them. Very curious to here other preferencies as well.
I am pretty "conservative" when it comes to glues that I use -> Safe bets, not any exotic glues, but safe bets.
Tamiya has been my "preferred partner" so far, but the throne is shaking...
1. Still my favorite is Tamiyas Extra Thin Quick setting. Dries very quickly, but of course vaporizes also very quickly. But to glue together those small pieces quickly, for that it's great stuff. I think there is pretty much acetone in it as one of the main ingredients? Smells pretty heafty. And really melts styrene!
2. The "regular" Tamiya Extra Thin is used when I need a little bit more time to glue or I need to glue something delicate. As the Quick setting melts quite unforgivenly the styrene plastics this one is more friendlier.. Recently I have started to use this regular TET also to glue canopys etc.
Besides, the squarish bottle is perfect and stands pretty firmly (even if I succeeded once to flip it over also)
As a reminder the result of that accident behind this link
3. UHU glue is then used for bigger pieces, where you need more time to add glue in several places, without risking it to dry. Also, if I need some extra strenght, I use this pretty thick glue in places where it's not so important if there is one drop too much to make a strong bond. It has (not so clear in the pic) a long "tube needle" which works pretty good. Except that the glue dries usually in the tube when not used for some time.
Before I started to use the liquid cements, this UHU was the workhorse and was used for glueing practically everything in a build (except canopies).
4. Ammo Mig, I have only recently started to use it. It has a very long brush, something I found difficult to use, but after some practice not bad. I use it perhaps nowadays more than the regular Tamiya. Something I like with the long brush. he only bad thing is, that the bottle is very unstable. Had to constructe a simple "stand" before accident would happen.
5. The last is then the superglue, brand just happens to be the one in the pic, also UHU. Have not really used it that actively, only in certain situations, such as working with PE parts.
I mentioned above the special long brush tip by Ammo Mig. Here a close up of the brush tip compared with Tamiyas. As seen, Ammo's tip is almost 4 times longer than Tamiyas. But still stiff enough to be precise.
Then I cannot help, but the yellow cap somehow radiates "efficiency", powerful and modern glue.. it feels like the glue really grips well. But that is just a subjective characteristic, but still is.... :-)
Below some of my ex-glues. The relationship with these have just faded away... Once fresh and new, now old and tired.. Still having some responsibility for them, so they can stay and hang around still. Even if I am afraid Humbrols spirit has left the building and what is left is just some hard remainings in the bottle..
But what will the future bring ?
Mr Hobby Cement S and Gator Grip glue !
I am really curious to test them!
So, what's your take on Glues & Cements ?
Re: Glues I use
Glues I use:
  • 1. 3M Superglue
    2. Mr Cement S
    3. Mr Cement Deluxe
    4. Pacer 560 Canopy Glue
    5. Gator’s Grip Thin Blend
    6. J-B Weld Epoxy
Re: Glues I use
Tamiya Extra Thin liquid glue
Testors orange tube glue
Gorilla Super glue tube
VMS Flexy 5K CA Glue for Photo-Etch - this stuff is far superior than Zap-a-Gap stuff
Pacer Formula 560 Clear canopy glue
Tenax 7R
Re: Glues I use
Tamiya Extra Thin
Ammo of Mig
Mirco Krystal Klear
Zap-A-Gap Super Glue
Re: Glues I use
I use the following:
Tamiya Extra Thin
Tamiya Regular (Orange top)
Testor's orange tube glue
Gator Grip Glue (for P/E)
Microscale Clear Parts Glue (for canopies and clear parts)
C.A glue (for P/E and resin)
I also occasionally use Tenax 7 when I want a good fix; as well as Ambroid Pro-Weld.
I also have an old tube of Pactra glue that is still good.
Re: Glues I use
Tamiya Extra Thin
Testors clear
BSI "Insta-cure" medium CA
Re: Glues I use
All three versions of Tamiya´s best: quick setting, extra thin and the thick one. I still use super glue in thin and gel type, but I find more and more options to work with UV sensitive glue! Lot´s of time to adjust parts, then hit it with a flash of light from a UV lamp and it´s set! Lovely stuff!
Re: Glues I use
Thomas_M wrote:All three versions of Tamiya´s best: quick setting, extra thin and the thick one. I still use super glue in thin and gel type, but I find more and more options to work with UV sensitive glue! Lot´s of time to adjust parts, then hit it with a flash of light from a UV lamp and it´s set! Lovely stuff!
UV sensitive glue, interesting! Any brands you would recommend ?
I will drive tomorrow to Frankfurt for a couple of days and could do a de-tour to a suitable shop if you recommandation is a German product or to be found in German stores.
(I use Bondic, that also reacts to UV light, but it's not really glue as such. )
Re: Glues I use
Kari, I bought my first bottle of UV glue at a hardware store. Label says "Solacor", maybe you can get your hands on up North, or in such a shop near Frankfurt. I recently bought a much stronger UV lamp on the big "A", and got two bottles of this glue from China for a bargain. Should last the next years...
On store in or near Frankfurt: be aware there is another Frankfurt in the Eastern part of Germany, called Frankfurt (Oder). You could do a shop search on Revell´s homepage.
Re: Glues I use
Thomas_M wrote:Kari, I bought my first bottle of UV glue at a hardware store. Label says "Solacor", maybe you can get your hands on up North, or in such a shop near Frankfurt. I recently bought a much stronger UV lamp on the big "A", and got two bottles of this glue from China for a bargain. Should last the next years...
Thanks Thomas, will take a look in stores tomorrow !
