Moin Moin,
The F-21A Lion obviously is equipped with the Martin Baker IL10P Seat
I did not find anything in the aftermarket range searching for this seat. Does anyone know, if there is something in resin for the F-21A (A Seat or eventually a complete new cockpit section?) Also, is there any other aftermarket stuff for the 72nd scale F-21 like Nozzle, Wheels etc?
Thanks a lot for your help and input
Ejection Seat F-21A Lion (72nd Scale)
Cheers
Tim
Member of PMC Kurpfalz Mannheim
Tim
Re: Need Help on 72nd scale F-21A Lion
It does not look like there is much out there for the F-21, let alone the Kfir in 1/72
Would this seat work? It's a MB Mk.10, but I don't know what variant of that seat.
https://store.spruebrothers.com/product_p/cmkq72254.htm
I just searched a little bit further and found a nice discussion in arc forums:
http://www.arcforums.com/forums/air/ind ... tion-seat/
Seems the Kfir C.2/F-21 had the early type Martin Baker Mk.6 on board. This would make the search for a resin replacement a little bit easier, I think....
Cheers
Tim
Tim
Frundsberg a Walkarounds Around on Prime Portal. Last (4th) Pictures. Semester like a Mk.6 with two handle.
http://www.primeportal.net/hangar/isaac ... /f-21a_11/
Also here...
http://data3.primeportal.net/hangar/wei ... _of_73.jpg
Also here...
Cheers
Tim
Tim
