WW2 1946 GB Official Thread
Member created Group Builds
Re: WW2 1946 GB Official Thread
neato
Great work on the turret Paul!
My progress has not been that spectacular. I finished the pilot in Dräger pressure suit. Not very accurate but close enough for 1/72 scale. I also added a small instrument panel and gun sight in the cockpit. With everything installed it is nice and busy.
Paul
Post by Paul »
I know its been a little bit since I have posted anything on this. I assembled the wings and the wing fold only to be disappointed again in the way things worked out. I was hoping for the outer wing panel to line up with the inner wing panel but alas no joy.
here is the way it looks going together. Image
well it looks as if I will be displaying this with wings stowed, I just hope that the Skyraider doesn't have this problem.
@ Paul: Looks like the TBM kit was designed to be displayed with the wings folded....
Here is a progress pic of my build, I scribed the lines of the moving parts. I also added a PE loop arial and drilled out the gun barrels. I am painting it now, grey with yellow wing tips:
Paul
Post by Paul »
I decided to build this with the wings extended. After I had the flaps and the other necessities glued on the outer panels just sort of lined up, sorta. With a little tweaking here and there I came away with something pretty dang close. not too much filler and the gaps in the wing halves are covered with a fairly large piece of pe.
My next concern is WHERE THE HELL AM I GOING TO PUT THIS BEASTIE? Well that's for later. any hoo, this thing measures about 22" port to starboard and I really think I will have to do some re enforcements inside the wing through the gear bays.
The cutting mat is 24" wide and you can see in this last pic how much room this thing takes up.
scorpiomikey
Post by scorpiomikey »
@Paul
Wow, she is a monster. Great work so far.
@Borg
Nice work, be careful you dont scribe too deep, remember, she was made of wood.
scorpiomikey wrote:
@Borg
True, but I am not scribing the panel lines (because it was made of wood) These are just the ailerons.
Paul
Post by Paul »
I am pretty sure that it will be quite the show stopper,Borg
Paul wrote:I am pretty sure that it will be quite the show stopper,Borg
I wil do my best!
Here is some more progress, yellow for the wingtips.
Next up, grey. And maybe some motteling.
Looking good. I think I have a bottle or two of Mottled paint. Love the mechanical arm - Doesn't that create drag?
Return to “Member Group Builds”
